Viewport Frozen Layer still Plotting While Publish
Selva_Ganapathy
Selva_Ganapathy
There are multiple sheets in my drawing file.
In my drawing, I have included the externally referenced file.
I freeze certain layers in my viewport.
However, when I publish, the frozen objects are shown after publishing.
tcorey
If you _PLOT the same drawing are the results the same or different?
Tim Corey
MicroCAD Training and Consulting, Inc.
Redding, CA
Autodesk Platinum Reseller
New knowledge is the most valuable commodity on earth. -- Kurt Vonnegut
EliANewlines
Set VISRETAIN = 1
Selva_Ganapathy
If i use plot option the drawing output is ok.
chriscowgill7373
would it be possible to provide a screenshot of your publish dialog?  is background publishing checked?  I have had more troubles than it is worth trying to do background publishing, so I dont check that box, and it seems to make the drawings plot faster, and I have less issues with how thing plot.  Yes, it ties up my software while it is publishing, but not having to republish makes it a quicker operation in most cases.
Christopher T. Cowgill, P.E.
Civil 3D Certified Professional
Civil 3D 2024 on Windows 10
