Datum corridor surface not generated properly (Creates surface in only 1 region)
cyberflow
Advisor Advisor
cyberflow
Hi
I am trying to create my datum surface and it creates it from one region only (green triangles in printscreen) :
I can't really
Not sure if anyone here can help me out or maybe it's a known bug ?
Thanx in advance !
Frank Freitas
CAE/CAD/BIM Coordinator & Support Specialist
LinkedIn
jroot
Can you attach the DWG so we could take a look?
cyberflow
Hi @jroot,
I'd really want to but contractually i'm tied and can't share the file
Frank Freitas
LinkedIn
cyberflow
Well i've found the solution after playing around with the corridor and talking to a collegue about my issue :
I had frequencie that was too high (@ 0.5m - I know i know, it's intense)
Brought it back at 5 meters everywhere and it make the surface now
I need to clean it up but if it helps someone to know that there's a limitation  in the number of links outputed by the corridor to create a surface corridor 🙂
Your welcome !
Frank Freitas
LinkedIn
cyberflow
For those who don't believe it 😛
Frank Freitas
LinkedIn
