After I fix the crossing figure the database still shows a problem. Even if I fix it in the csv, delete the csv from the database and import it again it still shows as crossing. It's like it doesn't get deleted out of the database or know that it has been fixed. Am I missing something.
Solved by rl_jackson. Go to Solution.
The shield does not mean that its a crossing figure issue. I find those appear when curves are not tangent or something in the coding of the figure is amiss. You can usually get those shields to go away by selecting the figure name, right clicking and selecting save from drawing.
Rick Jackson
Survey CAD Technician VI
Ahh you are correct. I knew when I shot it, something was going to be wrong. Begin, POC, POC, End. I needed a third POC. So I just changed the End to a POC.
