Civil 3D Forum
Data shortcuts
2 REPLIES 2
138 Views, 2 Replies
Data shortcuts
Like adviced in thread "Civil3d hardware" I have divided my project in few
files using data shortcuts. Now I have dwg for surface, dwg for alignment
referenced with surface, dwg for profile referenced with surface and
alignment, dwg for corridor and sections referenced with surface, alignment
and profile. I can see that changing alignment tangent intersections is much
faster now.
Is that how you do it?
2 REPLIES 2
Sounds like you got it. With 2008 you could also go one step further out...
your sections can be in a separate file.It is a slightly different process
though. You dref the alignment so you can do the sample lines; you xref the
corridor file... 2008 will sample the corridor from an xref! This really
sped up both the corridor and the section regeneration times for me.
Larry Bettes
ADT, C3D (& LDT/CD)
(06, 07, & 08 with all SPs installed)
P4 - Dual Core 3.0 GHz, 3.00 GB RAM
nVidia GeForce 6800 GS AGP - 256 MB
Windows XP Pro, SP 2
kcobabe
I would try to get a SQL server and use vault if I were you or run Vault local on your machine. Data shortcuts can be a major pain and several errors can result from them (multiple references is one that I have sent to Autodesk).
R10 - 2020 ACAD
2008 - 2020 Civil 3D
2014 - 2020 Plant 3D
2014 - 2020 Revit
V8i - V8i SS4 Microstation
Infraworks
2018-2020 Inventor
2020 Navisworks
Rail Community
