I am just trying to follow what you did with Contours yor recieved.
AP-Contour Drawing has lots of polylines with elevations.
Did you create the surface here? (See www.civil3d.com/index.php/2007/02/son-of-the-polylinethingy/ )
Did you add the additional topo here as points or a point file?
Did you snapshot your surface?
The XML file - is that a Datashortcut or did you LandXML that final surface out into another drawing?
Matthew Anderson
Civil 3d SP3 2007 / Beta 08
Matthew Anderson, PE CFM
Product Manager
Autodesk (Innovyze)
