Data reference a surface from DEM
Joe-Bouza
Mentor Mentor
Message 1 of 28
Joe-Bouza
This can be done right?
I created a source file from DEM added to the datashortcut project ... it worked
now I go back to the host and no elevation data is evident. yet the surface is in the prospector with no error indicated
Joe Bouza
Replies (27)
Message 2 of 28
Hidden_Brain
Joe,
I haven't seen this happen. when you go back to the source file, does the dem list as path under definition?
Message 3 of 28
Joe-Bouza
Everything looks correct.... except the data doesnt show Smiley Frustrated
Joe Bouza
Message 4 of 28
Hidden_Brain
betcha the super cool feature "levelofdetail" is in play Smiley LOL
Message 5 of 28
Joe-Bouza
I made another DEM surface and added a dataclip this time. seems to be okay for the moment in terms of data.
Ill keep you posted
Joe Bouza
Message 6 of 28
Joe-Bouza
I wish.  zeros in my surface profile
Joe Bouza
Message 7 of 28
Joe-Bouza
Still loosing the surface
Joe Bouza
Message 8 of 28
Pointdump
Joe,
You're losing the Surface in the Source(Data Ref) Drawing?
Dave
Dave Stoll
Las Vegas, Nevada
NVIDIA Quadro P5000 16GB
Windows 10 Pro 64 / Civil 3D 2027
Message 9 of 28
Joe-Bouza
Hi Dave
The host drawing is not getting any data from the surface. The surface profiles went static and the pipe network structures loose the rims
Joe Bouza
Message 10 of 28
Hidden_Brain
wild guess:
if you keep both source and host files open, qsave the source file and then with it still open, synchronize DS in the host file, any change?
Message 11 of 28
Joe-Bouza
I try after dinner 🥘
Joe Bouza
Message 12 of 28
Joe-Bouza
hello Avishek
I think it is fixed. all conjecture but it works now
here is the chronology.
1. Created DEM surface
the scope creeped and I need more DEM
2. deleted the first DEM and made the larger one with appropriate data clip
3. created data shortcut
4. surface and profile started to vanish in the host drawing and not display in the parent drawing.
5. found layers turned off in the parent drawing that contained proxy objects that would not delete.
6. made new file data refed the DEM, promoted and saved over the original source file
all appear to work now
Joe Bouza
Message 13 of 28
tmachado
Hi @Joe-Bouza , I am having this issue, the DEM DS shows in the file but is empty no data on the surface, if you promoted in the file is just an empty ground.
The project I am working on is extremely big and the only manageable way to work it is creating DS from Tiff but they only work once you create the reference in the file, if you close the file and reopen it the surface is gone.
Hope this will help!
Was this answer helpful? If so, please click the ACCEPT AS SOLUTION or the LIKES button
Tatiana Machado
BIM Manager/ Autodesk Certified Instructor
Blog | Twitter | LinkedIn
InfraWorks Ambassador
Message 14 of 28
Joe-Bouza
Hi Tatianan @tmachado  this one was a puzzle. i have not had to work on this job since and have no new report on the solution.
Joe Bouza
Message 15 of 28
I too have this problem now (C3D2018). In drawing A I create a DEM surface from a .tiff file and create a DS for it. In drawing B i reference this surface and work for a day. The next day when I open Drawing B my references surface is 100% empty. The surface object is there but is has no data....
@lim.wendy
Getting real tired of this ****
Message 16 of 28
jmayo-EE
Has anyone tried creating a snapshot of the source surface before setting up datashortcuts?
Has anyone tried pasting the source TIN into a new empty surface and datashortcut the new surface?
John Mayo
Message 17 of 28
tmachado
Yes, that doesn't work either, the way we have made work is relinking the DS surface reference using the Data Shortcut Manager everytime you open the file
Tatiana Machado
Message 18 of 28
lim.wendy
Interesting discussion...
Thanks for letting me know... I'll research, search internally and see if this has been reported and keep all of you posted!
Wendy Lim
Data Nerd | Community Advocate | AEC Industry
facebook twitter twitter blogs pm
Join the new online Rail Community
Rails Summit
Message 19 of 28
Neilw_05
I wonder if you are losing connection to the DEM file that was used to create the surface. I know if you create a surface from a LandXML file, the surface creates a link to the LandXML file in the definition. If the LandXML file changes you can update the surface by rebuilding, as long as the file path hasn't changed. If the file gets moved or renamed the link gets broken and you end up with just a snapshot but no data. So check the surface definition and see if the link to the DEM file is intact.
Neil Wilson (a.k.a. neilw)
AEC Collection/C3D 2024, LDT 2004, Power Civil v8i SS1
WIN 10 64 PRO
http://www.sec-landmgt.com
Message 20 of 28
Update:
The issue was apparantly that the dwg had lost its association to the Data Shortcuts folder.
The DS folder in Toolspace looked like this initially, but when i changed the DS folder to the correct one the surface once again had data in it...
The surface also did not have "geometry stored in drawing" set (it was set to "Reference only") so thats also probably the reason the data was not in the drawing.
I guess I can't blame the software for this one 🙂
Thx for the help though
