Hello!
I'm bothering you with a problem.
I have made the longitudinal profile of a road. In the data bands I want to represent the EG (COTE TEREN), FG (COTE PROIECTATE) and difference between them FG-EG on sample lines. I have put at existing elevation - Profile 2, projected elevation - Profile 1 and at difference Profile 1-Profile 2 (in data bands - Picheti) but the data Profile 1 and 2 are the same and the difference between them is 0. For major and minor station works...Where am I wrong?I attach the drawing
Thank you!
Translated with DeepL
Solved by gleonhardt. Go to Solution.
Hi Alexandru,
the Data in the band "Differente in axa" defined in band "Picheti". When you use two different data sources in this band, than it works.
But you get overlappings in the band "Different in axa". There you should switch of the values for main, minor and alignment.
Hope this helps.
Best regads
Leo
