Dashed Linetype ends are solid
kavin.malarkannan
Observer Observer
kavin.malarkannan
Observer
Observer
When I create a custom dashed linetype, the ends are not spaced in a dashed manner. I have attached a picture that shows the issue I am facing. Does anyone know how to fix this either in the .lin file or in c3d? Thank you!
Matheus-Lima
Hi @kavin.malarkannan, probably this is related to the length of the line. Did you try to stretch it and see what happens? Unless the length of the line is a multiple of the length of the patterns, it's usual that at the beginning and / or at the end the line becomes solid.
Check this thread: https://forums.autodesk.com/t5/autocad-forum/custom-linetype-dashes-at-beginning-and-end-are-longer-....
Hope it helps!
[PT-BR] Se essa postagem foi útil para você, clique em Curtir! Se a resposta resolveu o seu problema, clique em Aceitar Solução.
[EN-US] If it was helpful to you, click on Like! If the answer solved your problem, click on Accept Solution.
Matheus Lima
Civil Engineer | BIM for Infrastructure Enthusiast | BIM Manager | Instagram @bim_infra | LinkedIn
ChrisRS
Edit: @kavin.malarkannan, this reply should have been to your initial post. Thank you for the like, Matheus.
 You might benefit from using the obscure and possibly unsupported "S" (stretch?) type alignment instead of the "A" type alignment.
You would need to edit a copy of the line type definition.
I have used this successfully in the past.
All is explained in the following link: custom-linetypes-s-type-instead-of-a-type-alignment
Christopher Stevens
kavin.malarkannan
Observer
Observer
Thanks! The stretch works fine for longer lines but I am running into the issue of overlap when the line is short. Do you know how to fix this? I have attached an image showing the problem.
rl_jackson
How was the linetype created, using the express tool or manually in the ACAD.lin file.
Can you post the how the text from the *.lin file.
Rick Jackson
Survey CAD Technician VI
KirkWM
To me, it looks like you might need a "bigger" negative number after your text componentScreenshot 2022-12-14 161255.jpg
