DASHED LINES NOT APPEARING DASHED
wendy.mercado
wendy.mercado
Dashed lines are showing as continuous lines, I already tried msltscale and psltcale and the issue is still not resolved. Having the issue only with one file. Any help is appreciated.
user181
What do you have them set to?  Normally msltscale, psltscale and ltscale are all set to 1. If this doesn't work maybe each line has a linetype scale assigned. Check by selecting lines and looking for linetype scale on the properties palette and make sure they are 1.
Or post the drawing.
Joe-Bouza
In addition to @user181  advice...Does the line have z values? steep lines can have difficulty displaying types
Joe Bouza
wendy.mercado
I restarted the computer and it did the trick. Thank you
Wojtek_Garczewski
Hi @wendy.mercado
Thank you for your feedback. I'll tag your answer with "Accept Solution" label, so solution will be visible for other users better.
Wojtek
Wojtek G.
Product Owner for Civil 3D
Civil Engineering Solutions
