Cut Only Ditch
Cut Only Ditch
ecursonmsmm
Message 1 of 14
Cut Only Ditch
ecursonmsmm
I need help creating a cut only subassembly (if this is possible). The ditch has a flat constant bottom and each side has a constant side slope to daylight. What I need to remove is the fill aspect of my crude subassembly. Hopefully the pictures will show my intent. Please let me know if any more information is needed.
Screenshot 2026-06-16 111341.jpgScreenshot 2026-06-16 111328.jpgScreenshot 2026-06-16 111304.jpg
Replies (13)
Message 2 of 14
cwitzel5NL5H
You might try a Conditional Subassembly.  I haven't used them in a long time, but that may work in your situation.
Conan Witzel
Herrera Inc
Message 3 of 14
Radwan-Almsora
Yes, you can create a cut-only ditch subassembly. The easiest method is to use the BasicSideSlopeCutDitch or Ditch subassemblies, or build a custom setup using ConditionalCutOrFill tools in AutoCAD Civil 3D.
To resolve your issue, you can enter here.
Ditch
Message 4 of 14
ecursonmsmm
I am not seeing a BasicSideSlopeCutDitch subassembly. I do believe I need to create a Conditional Subassembly but I am quite unfamiliar with the tools to do so. Any help would be greatly appreciated.
Message 5 of 14
AllenJessup
It's on the Basic tab.
Allen Jessup
CAD Manager - Designer
Message 6 of 14
ecursonmsmm
thank you for the response. Unfortunately I don't think that will not work as it has cut and fill in the subassembly and the subassembly start is from a feature where I would need the ditch to be centered on the profile line and baseline. If I am wrong please let me know how I would accomplish this.
Message 7 of 14
fcernst
Yes you need cut fill conditional subassemblies on each toe left and right then when you’re cut do your outer cut and daylight work and when you’re in fill do nothing. cut work you’re gonna have to daylight as normal going outward, but then daylight coming back at flat slope from the proposed toe location to hit the inner existing channel bank.
Fred Ernst, PE
C3D 2027
Ernst Engineering
www.ernstengineering.com
Message 8 of 14
ecursonmsmm
I don't believe you understand what I need. There is no fill in the entire project only cuts. The object is created from the design profile at the centerline. This profile can be below or above existing grade. The width of the ditch is a set width and the slopes are a set percentage. So the ditch could be cutting from top of bank to the other top of bank in one scenario and the opposite scenario it would create nothing as the entire design section could be above grade. If I am misunderstanding your explanation, I don't know exactly what you are trying to articulate.
Message 9 of 14
fcernst
Yes I understand..that's what my solution does.
"In fill do nothing..'
Fred Ernst, PE
C3D 2027
Ernst Engineering
Message 10 of 14
ecursonmsmm
Ok I think I have found what you are referring to. I am going to try it out. I didn't realize that particular subassembly was only cut or fill not both and it seems I need to set the bottom slope to 10000000:1 to get a flat bottom. I will let you know if it works out.
Message 11 of 14
fcernst
maybe you haven’t used the conditionals before ..so I’m talking about at the conditional test point locations, which are your toes left and right ..if your toe ends up in the air that is a fill result..do nothing
Fred Ernst, PE
C3D 2027
Ernst Engineering
Message 12 of 14
ecursonmsmm
The issue I have now is I have no cooridor anymore. That subassembly does not create points or links to then make the corridor. What am I doing wrong now?
Message 13 of 14
ecursonmsmm
I see what you are saying now. The issue I am coming across is that I will have more scenarios than I want to count. Maybe I am asking the wrong question. My corridor was fine with the exception of the fills. Is there a way to export only the cut for plan view contours and cross sections?
Message 14 of 14
fcernst
no it has to be correct. Use generic links for the test links that reach out and do your bidding, but don’t use them in your surface definition.
Fred Ernst, PE
C3D 2027
Ernst Engineering
