how can one create the cut file conditional subassembly or the horizontal conditional subassembly using subassembly composer? if i get the idea i think life will be soooo easy
Conditionals (if/then) switches are part of Subassembly Composer. There should be examples in the help system that show how to use those. For the cut/fill what you'll do is set a target surface in the subassembly and then test your points to see if they are above or below that surface.
Peter Funk
Autodesk, Inc.
what i want isjost to creat the conditional and it shows as a layout as the cut fill assemly which comes from out of the box does. i can use the subassembly composer well just i can creat the condition.
What I meant was that I can use the switch, decision and all just what i dont knw is tht when the decision is true wt should i put and when the decision is false wt should i put when creating so tht the conditional subassemly does work as the out of the box cut fill sub
That aint good coz ppl want other types of condition other than the OOTB. and i do it all in sub composer bt i have to creat the whole assembly like the lane ditch and daylight together to achive wt i want and i dnt want tht coz it is difficult to manupilate
Normaly what i doo is creat the whole one side as one but tht is not flexable to work on different project
They called it Subassembly Composer for a reason. There is a huge advantage to creating Custom SAs as independant SAs vs. all as one complete one.
Now looking back on a library of custom SAs it's worth the effort to keep that thought process in place. As for adding a condition to a Custom SA, you will need at least two applications. If you have one on one side in that said condition, have option 1 do what you want it to do, and in option 2 have it draw a line at 0.
Having your next SA attached to that should give you options.
What Do You mean by two applications? What i want is just to have a dicition where when true it will do wt is attached to tht conditional sub on the assembly and if false to stop
Were you ever able to find a solution to this problem? I would love to create my own conditional sub assembly as well but have been unsuccessful as of yet.
The solution is to code the subassembly in .NET. The Composer doesn't have the ability to duplicate exactly the behavior of out of the box conditionals.
