Hello -
I posted a similar question earlier, but have not had any responses. This is a different file...with same problem.
I created a datum surface from the corridor and I am isolating the are under the curb, so I hid the middle. I created these boundries by adding them interactively from the corridor and selecting the Back of Curb and Flange. You will see that the datum surface is being displayed properly and only the area under the curb is showing up for the datum surface.
Then I am comparing the existing surfacing (XG-9) to the datum surface to get my cut/fills under the curb. However, in the cross sections the edgo of pavement to edge of pavement is being included in the cut, which is NOT what I want to happen.
Any ideas why this is happending? The problem occurs at the interesction baselines.
I am working in Civil 3d 2016
Thanks in advance for any guidance!
