Civil 3D Forum
Cut and Fill volumes
5 REPLIES 5
328 Views, 5 Replies
I am trying to create a cut and fill volume between my eg surface and the sub base surface of my roadway.
As it is now my fg surface is the top of the pavement.  Is there a way to adjust the fg surface down 5" to the sub base surface to calculate a new volume which would exclude the roadway?
Mick Nutter
5 REPLIES 5
How did you create the surface?
Assuming it's a corridor, you can create a SG surface from the corridor using the bottom links.(see attached)
Please accept as a solution if this solved your problem, and Kudos are always welcome!
This lowered the elevation by 4".  My subassembly is 5".  Is there a default setting which is set to 4"?
Mick Nutter
When you created your SG surface, did you specify that you're creating it from the datum? (see attached) you may be selecting sub-base
I did have it set to the sub base and changed it to datum.  It still subtracts 4.
Hmmmm... Ok
  1. Double check your assembly (or assemblies) to confirm the 5"
  2. Double check that you're using the correct assembly.
If you're still having problems, I'd be happy to check it over if you can send me the file.
Rail Community
