Civil 3D Forum
Custom Range Color Scheme?
4 REPLIES 4
darreng_oa
2387 Views, 4 Replies
currently my choices are of Range color scheme are: blues, greens, hydro, land, pastels, and rainbow, from which I use rainbow the most.  Unfortunately, the elevations assigned to red spectrum are opposite what i need, so i have to reverse each range manually.
Is there any way to Save As is the Surface Analyis box, or create a custom Range Color Scheme?
thanks
4 REPLIES 4
Out of the box, there is not a way to do this that I know of. I did however write an app that allows for this for any surface analysis. It stores the data in an external file you can easily share with others and import/apply to another surface.
https://apps.exchange.autodesk.com/CIV3D/en/Detail/Index?id=appstore.exchange.autodesk.com%3ac3dimpo...
Steve Hill,Civil Designer / .NET Developer / AutoCAD and AutoCAD Civil 3D Certified Professional
http://redtransitconsultants.com/
Autodesk Exchange Store
Twitter | LinkedIn | YouTube
Hidden_Brain
in reply to: darreng_oa
I am sorry to not contriburte with anything meaningful.
I just wanted to let AutoDesk know that this kind of feature would be very popoular! I have discussed this issue with a lot of collegaues, and this would improve workflow or/and quality of drawings etc. we make.
I.e. the feature would be to "create specific color schemes" for e.g. elevations, that later could also be ipmported as styles in settings etc.
And lisps, API, etc. is too complicated for our use, only a handful at most would know how to use it. So it has to be "idiot proof", as most things are in the regular C3D, haha.
Regards Hallvard
I wrote a Dynamo script to do this, makes it nice as I can setup the ramping for our company standards.  You can check it out here.  http://c3dk.com/2024/02/28/automate-surface-properties-analysis/
Hope this helps, I hate that this hasn't improved over the years.
I spend time on this forum because I enjoy Civil 3d and getting your likes.
Check out my Civil 3d blog at: http://c3dk.com/
Favorite Posts: Use Dynamo For Surface Analysis: https://youtu.be/eJNdX6guMP8
Rail Community
