Custom Point Label Style Question
MatTheDrafter
MatTheDrafter
How would one delete a text component, such as Point Number, from the drop-down list? I am attempting to make a point style that only shows the elevation and descriptor. When I select Point Number, I am unable to delete it.
MMcCall402
It could be that the point number text component is being used as the anchor for another component.  Check the other component's anchor objects.
Mark Mccall
CAD Mangler
VHB - Engineering, Inc.
tcorey
Don’t try to Delete it, just change its Visibility.
Tim Corey
MicroCAD Training and Consulting, Inc.
Redding, CA
Autodesk Platinum Reseller
New knowledge is the most valuable commodity on earth. -- Kurt Vonnegut
igi_pop
Hey,
when you select it, push the red X on the right of the list 🙂
Iggy
Custom build;ASUS Z790 Prime Z790-P;i5-12600KF @3.6GHz; ASUS RTX3070Ti 8GB GDDR6X; Win11pro x64; 128GB RAM DDR4; SSD 2TB 980 PRO M.2, PCIe 4.0 x4,
"I'd rather have a bottle in front of me, than a frontal lobotomy."
AutoCAD Civil 3D Certified ProfessionalAutoCAD Civil 3D Certified Professional
MatTheDrafter
How would I go about checking the component's anchor objects?
chriscowgill7373
if you look at the other elements, it will tell you what it is attached to
Everything is anchored to the Description, except the description, it is anchored to the feature
Christopher T. Cowgill, P.E.
Civil 3D 2026 on Windows 11
