- Mute
- Permalink
- Report
I'm having an issue with curved pressure pipes and IFC export. I have created 4 networks from objects, the exact same way. I two centerlines, one for each set, and use a small offset from centerline to create my networks.
I have to curve some segments of my pipe run, due to restrictive parts and such. All pipes look identical in object viewer and iso view.
My issue is that when I export to IFC, 3/4 networks show some form of curve, but the last is just a straight pipe (see attached image).
Does anyone have any experience with what causes this? What makes the pipe "curved" in IFC and what makes it ignore the curve?
Link copied
