Curve/Line Label Number Restart
JohnC_ISM
JohnC_ISM
so im trying to do line/curve tag labels and im telling it what number to start with for the next labels and it doesnt do it. so im not sure what im doing wrong.
how do i make it start where im telling it to or clear out the old labels ive already deleted
Replies (7)
srousey74V5X
I'm not sure I understand exactly what you're saying? If you've cleared out the old labels (erased them), you should be able to label them and it will start over at one. You may have to change all of your values to 0. I've had the labels get hung up in the past for whatever reason. You can select the label and choose "renumber tag".
Civil 3d 2023
Processor Intel i7-13700K Sixteen Core Enhanced Performance Processor
System Memory 32GB DDR5-4800 MHz (2 - 16GB DIMMS)
M.2 Storage 500GB SSD NVMe/PCIe 4.0 M.2 Drive Expansion Card Slot(s)
NVIDIA RTX A2000 12GB
Operating System Microsoft Windows 10 Professional Edition
System type 64-bit operating system, x64-based processor
JohnC_ISM
I did that I deleted the labels and even changed the starting tag to what I wanted it to be and it still kept counting as if those tags still existed.
Renumbering tags works if you want to click on each individual single label. Which isn't the most ideal.
rl_jackson
I believe you also need to change the tag creation start # above as well.
Rick Jackson
Survey CAD Technician VI
srousey74V5X
Did you reset all the numbers in the Table Tag Creation area or just the renumbering area?
Civil 3d 2023
JohnC_ISM
Im not sure what the table tag creation area is. I changed whatever is in the screenshots
srousey74V5X
In the dialogue box, you have "Table Tag Creation" and "Table Tag Renumbering". Reset all of them to 0 in both areas.
Civil 3d 2023
wfberry
Perhaps I go back too far but back in the day you had to delete the "line" that the previous tag was used on.
Bill
