Curve Length (NA)
Curve Length (NA)
Message 1 of 10
Curve Length (NA)
Hello!
How can I enter "curve length (NA) value"?
Curve lengthCurve length
Accepted solutions (3)
Replies (9)
Message 2 of 10
Jeew-m
The easy way would be this.
Just create a profile with PVI stations at 0+00, 8+00 etc. You can roughly enter stations and make them exact using the parameter editors later.
Then add curves with length specified stations using free vertical parabola.
Once the profile is created you will realize what you have misunderstood. 🙂
Jeewana Meegahage
Design Engineer
Autodesk Civil 3D Tutorials
Facebook | YouTube | LinkedIn
Message 3 of 10
I did as you said. But I do not understand, what "curve length=(NA) value" means.
Message 4 of 10
wfberry
It says NA (not applicable) because there is no curve at the beginning station and the ending station.
Bill
Message 5 of 10
Jeew-m
The curves are related to the second PVI and the one before land PVI. First and last PVI have no curve information. They are part of the curves in the second PVI and the one before last PVI.
Jeewana Meegahage
Design Engineer
Message 6 of 10
wfberry
You have 3 tangents with 2 curves, I rest my case.
So what do you think NA stands for?
NOT APPLICABLE
Bill
Message 7 of 10
Jeew-m
No. The first curve is a part of the first tangent. NA really not suited here. first and last items are entities not PVIs.
Jeewana Meegahage
Design Engineer
Message 8 of 10
What does " 250' "  value mean?  Does it mean 250 meters or 250 feet?
Message 9 of 10
Message 10 of 10
wfberry
You have 2 things that are normally associated with feet.
The stations in feet have a + followed by 2 digits. (1+00), metric normally is follow by 3 digits 1+000.
The 250' has an apostrophe ('), normally means feet.
(Sketch attached)
Bill
