Current Drawing Tab Loses Focus
Message 1 of 15
In the last few months, since we upgraded to 2017 from C3D 2016, the command line glitches out and refuses to accept commands.  I noticed a few days ago that it seems to be switching to the background drawing tabs, if I have any open.  I'll start typing a command and it sometimes gets one character on the screen and then stops taking anymore typing.  Sometimes I don't even notice until I hit enter and nothing happens.  I switched tabs the other day and there was all, or part, of my command in the command line.  It seems to happen while the current drawing is autosaving sometimes, but as I don't always wait for the autosave to save my stuff and I can't see what's happening in the background drawings, I don't know that this has any bearing on the problem.  The only solution I can think of is to not have more than one drawing open at a time, but that doesn't really seem very feasible.  Does this sound familiar to anyone?
Replies (14)
Message 2 of 15
rkmcswain
This was a much more prevalent problem in Civil 3D 2013, before a patch was released to deal with it. But I have a user topday, who is having the same complaint as you, in 2017.
I wonder if turning off level of display works as a solution in 2017 also?
Anyone else seen this in 2017? @Todd_Rogers @Jeff_M @wfberry @Joe-Bouza @Civil3DReminders_com @AllenJessup @Pointdump
Message 3 of 15
Todd_Rogers
Is a 4K monitor being used? If so, the new 2018.1 update SHOULD fix that.
Todd Rogers
Civil Administration
Message 4 of 15
rkmcswain
Nothing to do with monitors.
This is the bug where you are typing commands in the current drawing, but the text is going to the command line of another open drawing in the background.
Message 5 of 15
When it happens I use Ctrl+Tab to get it back to the correct drawing. I don't do a lot of design work recently, so I encounter the problem less and less.
I also noticed it happened less after I got a new computer. It might be a Windows Update issue. I was thinking about creating an app that would track what was active, but I lost interest in the problem.
Civil Reminders
http://blog.civil3dreminders.com/
http://www.CivilReminders.com/
Message 6 of 15
AllenJessup
I may have seen this once or twice. But it's not at all common.
Allen Jessup
CAD Manager - Designer
Message 7 of 15
Joe-Bouza
I've seen it in 2015 but thought it was a crumby keyboard. Got a new kb and don't see in 2017
Joe Bouza
Message 8 of 15
AllenJessup
This just happened to me.
Civil 3D 2017 SP1.1
Acad 2017    SP1.2
Allen Jessup
Message 9 of 15
rkmcswain
Message 10 of 15
AllenJessup
I'll see if I can confirm that a little later.
Allen Jessup
Message 11 of 15
AllenJessup
Just happened again. LevelofDetail was off in both drawings. I got some errors in the drawing I was not focused on.
eNotFromThisDocument
   at Autodesk.AutoCAD.DatabaseServices.TransactionManager.GetObjectInternal(AcDbTransactionManager* pTM, ObjectId id, OpenMode mode, Boolean openErased, Boolean forceOpenOnLockedLayer)
   at Autodesk.AutoCAD.DatabaseServices.Transaction.GetObject(ObjectId id, OpenMode mode)
   at Quux.SincpacC3D.EntityTracker.EntityTrackerPalette.SetControlValue(ObjectIdCollection ids)
@Jeff_M may have a comment on the last.
BTW I was trying to repath a Raster Image when this happened.
Allen Jessup
Message 12 of 15
That's weird. It indicates AutoCAD is switching documents, but still returning objects from the other document as the cursor is moving. It might be possible to have the SincPac monitor for the document change in this code and if it's different make the correct document current.
Civil Reminders
Message 13 of 15
Jeff_M
That is quite odd, as we get the current document from the Acad Application with each move of the cursor. This tells me that even the Autocad application doesn't know the document switched.
Message 14 of 15
g_k50
The problem solution is to minimize the drawing window and then resize.  The corrects the problem of not being able to type in your commands.  I don't know what's creating the problem but that's the solution that our office came up with locally.
Message 15 of 15
ceethreedee.com
We are getting the same issue on every single dell precision M6600 and even our newer 7710.
Switching back to another drawing and then back again on the tabs seems to correct it.
strangely if you use the dynamic commandline (F12) this is not effected.
Definitely another bug in 2017.
Civil 3D 2025 / Infraworks 2025
Win 10 -DELL Precision Notebook 7680
Want FREE TOOLS! Come get my free productivity tools for civil 3d from the appstore here Ceethreedee tools
Or from my website below!
https://ceethreedee.com/ceethreedee-tools
