CSV Format
CSV Format
shildebrand3NLK9
Message 1 of 17
CSV Format
shildebrand3NLK9
I am trying to import a point file that has long and lat not a format I've had to deal with yet so I made a new point file format.
when trying to use the new format it says does not match point file format but the previewer is showing everything is correct.
I upload CSVs daily without issue.
is there a trick to uploading in a long lat format? or is there something deeper at play I am missing here?
Replies (16)
Message 2 of 17
Asmir
Check decimal dilimter in CSV file. Or is it possible to share your CSV file.
Message 3 of 17
AllenJessup
Yes. Please share the file or at least a line or two so we can see the format.
Allen Jessup
CAD Manager - Designer
Message 4 of 17
Pointdump
Hi Shayne,
And a screen shot of your point file format.
Dave
Dave Stoll
Las Vegas, Nevada
NVIDIA Quadro P5000 16GB
Windows 10 Pro 64 / Civil 3D 2025
Message 5 of 17
Jeffrey_Rivers
Is there also a hidden gotcha where, if you have the .csv file open in Excel then C3D will refuse to import it?  It's been a while since I've used it, but I recall that there's no specific error message telling you to close the file.  C3D will just report the operation failed with no reason given.
Message 6 of 17
shildebrand3NLK9
Message 7 of 17
shildebrand3NLK9
Here is the CSV
Message 8 of 17
Asmir
First thing uncheck do coordinate transformation if possible.
Second export yours xlsx file format from Iexcel to csv. Then open your csv in notepad an check it . Coma should be delimiter and decimal delimiter should be point. If you have head column titles , remove it.
Save it as csv file. Then try to import it in civil.
Message 9 of 17
shildebrand3NLK9
 There is no header and it is an .CSV
and it opens in notepad in the correct format.  still will not work in civil
Message 10 of 17
Asmir
Could you please open file format you are using and take screenshot.
Message 11 of 17
Asmir
And also, try to save csv  file as txt file using notepad. And create new point file format for importing in civil 3d using txt file. And try this way to import points.  When you create ne file forma tray parsing on your txt file
Message 12 of 17
shildebrand3NLK9
Message 13 of 17
Asmir
Ok. The problem is in your file format it is not created . You need to name all.colimns
Number, lat, long, elevation
 just click on column name end pic k it. For all columns you have in csv .
Message 14 of 17
shildebrand3NLK9
my apologies as I have not found a format that works yet I am creating a new one every time and will save once it is successful.
When the naming schematic is done correctly I still am unable to upload so I assumed that was not where my restriction was.
here is a screenshot with the names correct done with the previous shared format.
Message 15 of 17
Pointdump
Shayne,
You'll need to assign a coordinate system before using a point file with Lats and Longs. Your point file format needs to be "DECDEG Lats" and "DECDEG Longs".
Dave
Dave Stoll
Las Vegas, Nevada
Message 16 of 17
shildebrand3NLK9
This worked!
Thank you very much
Message 17 of 17
Asmir
This is for sure because csv file was saved from excel. Please try with txt file created from notepad and with file format for import created for txt.
