Crossing corridor lines on a sidewalk
JoeKidd33
JoeKidd33
I have a sidewalk design that we are using a corridor with a LaneOutsideSuper subassembly and the links of the corridor are crossing over each other in areas where the walk deflects. See attached image. Is there a way to prevent this from happening?
Joe-Bouza
For this scenario you may want to use an off-set assembly for the sidewalk? Tough to tell from the image if the sw is a sub assembly of the main. One thin gfor sure: corridors do not like kinks in the alignment.
Joe Bouza
What if you were to create an alignment and profile at the outside edge of your sidewalk and targeted the subassembly to it? I think that ought to do it.
JoeKidd33
I already tried the target alignment at the edge of the sidewalk. The baseline alignment runs along the north edge of the walk. I added the transition alignment to the south edge. No dice.
tcorey
If you are using Civil 3D 2017, you can create your Corridor using a Feature Line for the baseline. If changes in direction are angle points, not curves, then the program will clean up these overlaps/bowties.
Tim Corey
MicroCAD Training and Consulting, Inc.
Redding, CA
Autodesk Platinum Reseller
New knowledge is the most valuable commodity on earth. -- Kurt Vonnegut
I just attempted this using 2017. I created 2 simple corridors, one with a feature line and one with an alignment. They both cleaned up the angle when I did it. Are you using an earlier version, OP?
JoeKidd33
Yes, we are using 2015, but moving to 2017 in January.
