When creating my cross-section in civil 3d 2016 I have a marker which shows a label and a elevation eg es 22.6.
I am trying to copy this exact label eg. text height and the line length etc and modify it to a centerline label.
Can this be done or do I have to create the label from scratch if so how?
Solved by Jeew-m. Go to Solution.
Dear Friend,
Identify the point code that relates to CL.
Go to assembly--> Assembly Properties-->Codes Tab----> Edit code set style
Select the desired point code and assign your label to it.
