Cross Sections for Vertical Surfaces
niluka_munasinghe84K94
How do I create cross-sections for the vertical surfaces shown in the attached image?
I'm new to C3D.
Any help would be greatly appreciated.
Sean_Fahey_10
Are you wanting hatches between your surfaces?  Depending on the type of cross sections we might be able to create something.
Thanks for the response, Sean. I want to create the cross-section from top to bottom of the vertical surface more like a front view.
sanetdikkumbura1950
Try this
1. Draw a polyline that intersects the two surfaces.
2. Home>create design>create alignment from objects>(select polyline and convert polyline to alignment)
3. click alignment>Launch pad>surface profile>select surfaces>add>Draw in profile view
hope this gonna be work.
Thanks Sanet. I'll give it a try 👍
