in the cross section view, my pavement cross fall is not same as defined in assembly. it shows 0.00% cross slope instead of -4.00% like in assembly. Any idea where I am making a mistake? How can I correct it?
this is cross sectional view
This is assembly defined
Solved by DRH_. Go to Solution.
What sub assembly is the pavement?
Do you have any vertical targets assigned you may have overlooked?
Joe Bouza
Hello, the problem is due to the superelevation, make sure you have these subassembly parameters set to none,
you can also delete the superelevation table from the alignment.
then rebuild the corridor.
