Announcements
Starting in December, we will archive content from the community that is 10 years and older. This FAQ provides more information.
cross section sheet plot scale problem
shamsmehany
shamsmehany
hi
i have created cross sections sheets from  a section view group
 my layout template was A1 template but i modified to A3 template from within layout setup manger
cross section sheets look nice in model space  but  in  paper space scale look weird
i want to know how to adjust the layout  to look like paper space  view
or i  miss something while generating the sheets
please . find attach file
thanks in advance
Replies (7)
sboon
First, make sure that your model space annoscale is the same as the viewport scale.  If you have modified the sheet layout then you might have to delete and recreate the section view group.
Steve
Please use the Accept as Solution or Kudo buttons when appropriate
Steve
Expert Elite Alumnus
shamsmehany
where can i find model space annoscale?
sboon
In the screenshot you posted it's visible at the bottom of the screen. It looks like the current model space setting is 1:100 but I can't tell what your viewport scale is.
Steve
shamsmehany
excuse me i really got confused there
could you please tell me the steps i shall follow to generate a cross section sheets
because results getting worse every time i play around both scales
thank you
sboon
I see that you're using the 2013 version of the software.  Unfortunately the process of creating section views has changed in more recent versions, so it's going to be difficult for me to help.
You need to make sure that the scale displayed through the viewport is the same as what you're using in modelspace.  Note that Civil3d will adjust the size of text and some objects when you change the scale, but it does not reset the positions of the section views.  Select one of them, right click and use the Update Section View Layout to fix this.
If you have edited a page setup which controls section view group then it may be necessary to delete the group and recreate it.
Steve
Steve
Jay_B
The 2nd png shows VP scale at 1:1000.
C3D 2018.1
C3D 2016 SP4
Win 7 Professional 64 Bit
shamsmehany
thanks Sboon ..thanks jay .. i just followed what you said and it solved the problem
 i set the scale to 1:100 for both annotation scale in  current  drawing  model  space and  source template view port scale .
i just wonder if any thing will change if i changed the paper size scale from page set up manger.
and why fonts in the result pdf file is pale
also, i will appreciate if any body could tell me in brief the differences between standard ,annotation and custom scales  in drawings
thank you
