Civil 3D Forum
Cross section problem
6 REPLIES 6
Ramin-AZ
454 Views, 6 Replies
Hello
I have two alignment and I drew two cross sections
There is no problem when the sections are drawn separately
I want to merge two sections, one of the sections is drawn in reverse
Thank you for your help
6 REPLIES 6
SoaresASBCAD
in reply to: Ramin-AZ
I didn't understand well, but I'll check
ASoares
Ramin-AZ
in reply to: SoaresASBCAD
One of the pictures is correct and the other is wrong
SoaresASBCAD
com dois alinhamentos, as seções serão de cada
"with two alignments, the sections will be of each"
Translated by Google
Traduzido por [@clacampos] através do Google Tradutor
ASoares
Ramin-AZ
I don't have any problem when I section for each alignment
I wanted it to be in one sheet for two alignments when I have two sections
Therefore, one of the sections is correct and the other is wrong
clacampos
Hi @SoaresASBCAD
You are very welcome to particiate in english foruns but please we ask you to continue in english as you did in the previous post.
Sua pergunta obteve uma resposta que resolveu a duvida? Então clique no botão 'Aceitar Solução ' .
Claudia Campos
Comunidade de Usuários Autodesk Português - Coordenadora
Ramin-AZ
in reply to: clacampos
I still could not solve the problem
Rail Community
