Cross section on layout
the cross section on model be readable the scale for model is amended to be 1:100
the problem is when trying to make viewport on the layout
of custom scale 10 which means the scale is 1:100
the cross section dont appear properly while when i explode it and make it on auto cad not on civil 3d everything was alright
kindly see photos below
and advice
Did you not regen after you set your viewport scale?  You should zoom to the items that you want to display in your viewport, set the viewport scale, then regen.
How to stagger the bands ticks to be in line with the labels (after making staggering for the labels)
Jeff_M
neezo89, you should never add a new question to another's post...especially on that is marked as solved. Instead, start your own post with the appropriate subject.
To answer your question, though, turn off the display of the ticks:
In the label style composer, add a line component:
Change the Text component to attach to the end of theLine component you just added, with a negative X offset:
And you get this result:
Jeff_M
I just noticed that you were adding onto your own original post, sorry about that. Although I still maintain that a separate new thread should've been started for the new question.
