Civil 3D Forum
Cross Section Labels
3 REPLIES 3
kevin.moranVRCAR
258 Views, 3 Replies
Hi, how do i edit labels circled in above snip. Thanks
Tags (1)
Labels (1)
3 REPLIES 3
Hi @kevin.moranVRCAR
What do you want to do with those labels? make them bigger, smaller, turn them off?
Regards!
Camilo Fernández
Civil engineer | Specialist in design, construction, and maintenance of roadways
LinkedIn
Yes, edit them in general
First, make sure which code set style you are using. Then go to settings and edit it here
You should look for the Link label styles here, specifically in your case "Pave1" according to your image
Access the label style and edit it according to your preference
I hope this helps. Best regards!
Camilo Fernández
LinkedIn
Rail Community
