CROSS SECTION LABELING
m.castaldi
m.castaldi
Hello everybody.
I need a help about cross section labeling.
Attached a generic cross section in which white line is existing ground and red line is design surface.
I wish to label design surface just in some points, yellow-highlithed in figure attached.
Which kind of label should I set as visible in style window?
If you select add labels from the annotation tab then go to section view. you can add labels there or from the sections pulldown go to add section labels.
M_Obradovic
Hi ,
I just Upload drawing with one bend set for cross section that you can control labels on specific point.
When you import bend set just set Surface 1 to be FG-Surface and Surface 2 to be EG-Surface.
m.castaldi
Thank you both.
Best wishes
