Creating profile along pipe network
joenaphazi
joenaphazi
How do I create a profile along a gravity pipe network that labels the network parts and associated specifications like slope, invert levels, manhole number, etc? The horizontal layout of my pipe network is not a straight path, so when I try to create the profile using "alignment from network" in launch pad, the created profile will show some pipes in elevation. I want the profile to cut along the network, just like it does in road profiles.
rl_jackson
So, first you need to create an alignment from your network to get a profile of just the gravity network. Is this what your doing? If not, Try creating alignment from network parts.
Rick Jackson
Survey CAD Technician VI
joenaphazi
I am creating alignment from parts. see the below screenshot with a double viewport. "In that profile view, you will notice the first pipe length in a weird direction". The other screenshot attached shows what I want to achieve.
Moreover, the bands are missing a lot of information that I would prefer to be included, as in the other screenshot.
Joe-Bouza
Your screen shots alludes to pipe profile along the road alignment and the pipe crosses and runs back on the alignment. the location of pipes and structures is taken radially from the alignment. Inspection of the pipe run one can see multiple places where the alignment station would be identical or at best nebulous. this is why civil3d folds the pipe back.
to get the second image I would have civil3d create alignment from the pipe (along the pipe) and then create label style expressions to label the road stationing. Or give stake out for the pipe alignment
Joe Bouza
joenaphazi
"I would have civil3d create alignment from the pipe (along the pipe)"... I thought this is what I was doing. I followed this procedure:
step 1 - select a pipe network part in the layout plan
step 2 - click on "alignment from network" from launch pad
step 3 - select parts of network
step 4 - click enter ..... it gives me a dialog box 1
step 5 - click ok ...... it gives me dialog box 2
step 6 - click on "draw in profile view".... it gives dialog box 3
step 7 - click on create profile view then find where to place the profile.
 That is how i am getting that sort of profile view which i am not liking.
Joe-Bouza
Ok. same problem due to the alignment folding back on itself.
Try adding a small radius at each PI. Specifically where the deflection is 90 and less
Joe Bouza
joenaphazi
I noticed that when selecting the pipe network pipes and structures to create in profile, you must follow the sequence (from the start of the network to the end).
Thank you
