Creating Linestyles with no extra Dash
PKINGSTON
PKINGSTON
Hello, online chat forum. I create a line-style for my company to use when designing roadways. I understand the spacing items on a basic level; if i need a 10' dash and 30' use code +10, -30. However, I see that the line generation adds a extra dash length at the beginning and end of poly-line.
Is it possible to remove or change the properties/commands for this additional dashing? Would you need to revise the line-style again to add different codes to beginning and end of poly-line?
jae.kwon
It seems that it takes the first draw length, splits for the beginning and the end if the line if a line will end with a gap.
I don't know of a way to turn this off.
ilia.borisov
lynn_zhang
Hello @PKINGSTON
Did you check the solution from the link above and did it help solve your problem? Let us know if you still need help.
Lynn Zhang
