Creating Lift Plan
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Hello everyone,
In our projects, we are frequently constructing pads, and clients often request lift plans. To meet these requests, we generate lift plans for every 300mm and calculate the volume for each lift. When the natural ground is flat, creating the lift plans is straightforward. However, when there are significant variations in the ground height, it becomes more challenging.
What I've been doing so far in such cases is creating a surface for each lift, limiting it between the existing ground and the design surface, then calculating the volume by comparing it to the existing ground. I subtract the volume of the lift below to get the volume for that specific lift.
I assume there might be a more efficient approach. I would greatly appreciate your insights and suggestions.
I'm uploading an example of our projects with the existing ground and the design surface here.
Thank you!
