Creating cross sections
Message 1 of 20
Hi Guys,
I posted on AutoCAD forum but was told to post here instead.
I have a topographical survey which has been produced using 3d polyline.
I am looking to cut a section and get the levels produced in a graph automatically.
Please where do I start?
Replies (19)
Message 2 of 20
joshua_alcock
That's quite a large request! But if you google the Bold phrases and work through them you'll be on the right tracks.
You need to create a surface and add the 3D polylines as breaklines.
You then need to create an alignment where you want to take a long section (road centreline?)
Then you need to create a surface profile from the alignment.
Then you need to create a profile view.
That will give you a long section view.
If you want cross sections along that alignment you need to create sample lines.
Then you can create section views.
Cheers
Josh
Message 3 of 20
Thank you Josh. I have been looking at youtube videos and am getting familiar with the terms.
WIll update if I manage to do it lol
Message 4 of 20
joshua_alcock
Not a problem.
Actually.
If you have your home ribbon up you'll find all the "create" options with in the left hand half of the ribbon.
Message 5 of 20
I created a surface on the topo and then just drew a poly line across where I wanted a cross section and done a quick profile, this showed the graph I wanted but I am not able to copy it
Message 6 of 20
joshua_alcock
The quick profile is temporary.
If you create an alignment (in your case I'd use select create alignment from object and select the the polyline you've already made when the options box appears be sure to uncheck the add curves automatically down at the bottom (frommemory)
then create a profile view from that you'll have a permanent profile.
Hope that helps!
Message 7 of 20
Jeew-m
Dear Friend,
The quick profile is temporary. You can create ground cross sections as desired.
https://youtu.be/c1PumORHYFk
But still you cannot copy them since they have dynamic nature. Once you create the cross section export the dwg to auto cad. Then you can copy cross sections.
Note: Try to export the dwg with quick profile as well and see it works or not. I am not pretty sure.
Jeewana Meegahage
Design Engineer
Autodesk Civil 3D Tutorials
Facebook | YouTube | LinkedIn
Message 8 of 20
wfberry
In addition to what others have said, for a quick fix, just explode it.
Bill
Message 9 of 20
Thanks all for help until now.
This is what I have done so far and this is where I am at.
-> Created a surface and added break lines.
-> Created alignment so under Alignments > Rails > alignments - (1) now
-> clicked on sample lines and clicked on sample line and it lets me move the cursor back and forth between the first alignment line.
-> produced a cross section as shown here  https://ibb.co/e81ELQ
The cross section profile is correct but I want the graph to show levels at these 4 fours as shown in this picture https://ibb.co/nhVkS5
how do I do that? as the blue lines are my running rails.
Message 10 of 20
I have all 4 lines selected as alignment already and the one thats showing as 113.754 is the first line i selected
Message 11 of 20
thanks explode also worked, any idea with my question above please?
Message 12 of 20
Bump pls any1 advice
Message 13 of 20
Jeew-m
It is all about code set styles.
Please follow the video.
https://www.youtube.com/watch?v=81pZIzHn7FY
Jeewana Meegahage
Design Engineer
Message 14 of 20
joshua_alcock
If you select the section view the second button on the left of the ribbon should be add view labels - Offset and level.
then click on those points marked in blue.
Message 15 of 20
josh, that's exactly what I need thanks but is there anyway to make it do that automatically at 4 locations as shown above?
Message 16 of 20
joshua_alcock
What marks those blue locations?
do they exist as 3D polylines or something?
Message 17 of 20
yes they exist as 3d polylines, they are the 4 running rails.
Message 18 of 20
joshua_alcock
click on your section view.
Far right of the ribbon Project Object to section view select your 3D polylines and ensure the elevations column is set to by object
hopefully your default label style will show you the elevation if not select the label and change the style.
Message 19 of 20
my friend you are a champ!
exactly what I needed! THANK YOU!!!!
Message 20 of 20
joshua_alcock
Not a problem!
