Creating Complex corridor in Subassembly Composer.
Soumya_K_G
Message 1 of 8
Soumya_K_G
I added an offset target to my subassembly (for example, to allow the edge of pavement or sidewalk to move left or right).
But when I change that offset value:
  • Some points move correctly(which connect using straight line).
  • Some points stay stuck ,don’t move at all (which has a a different shape other than a straight line mostly a complex shape ).
This makes the lines between them stretch or look broken, instead of everything sliding nicely.
How Can I solve this issue
Thanks in advance.
Replies (7)
Message 2 of 8
will_young
Which subassembly is this?
Message 3 of 8
Mike.M.Carlson
make sure the point types that are not moving with offset targets in SAC are assigned the appropriate offset or elevation target override or are somehow linked to points that are. Need to share .pkt...images don't really help.
Michael M. Carlson
Senior Civil Designer
CADD Manager
AutoCAD Civil 3D Infrastructure Design Professional
AutoCAD Design Professional
Message 4 of 8
nkiakas
Hi @Soumya_K_G
Can you share your PKT file to take a look?
Zip it before you attach it
Regards
Message 5 of 8
bim2BXKYR
It is a 2024 version
Message 6 of 8
bim2BXKYR
Thank you ,It works.
Message 7 of 8
Soumya_K_G
Thank you , the issue resolved.
Message 8 of 8
Soumya_K_G
@Mike.M.Carlson thank you, the issue is resolved as I created all the points relating to the Auxiliary point and assigned the target on the AP.
