I am trying to figure out how to export or create a .tin file from C3D. I currently bounce between C3D and Carlson Survey, both 2010. I need to create a .tin file of a surface for excavation purposes to be able to use in my data collector. Carlson Survey is very simple to use but the surface I create with CS never comes out properly and I have a difficult time trying to fix it. C3D makes an excellent surface but i cannot seem to export it into a .tin file extention that my data collector will use. I know that the surface can be created in C3D and then opened up in CS but I can't seem to get that to work either. I am open to a couple different options here, either: finding a way to create a .tin in C3D, figuring out how to get the surface loaded into CS, or getting my data collector (Allegro CX) to accept a .dem file extention or a xml. Any help will be appreciated!
