Creating a surface from polyface meshes
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
I have received a file from a landscape architect on a project I am currently working on, the architect have built the external levels model in Revit and it has been set up as a 'building' model which means that every object modelled is essentially a slab with a thickness (depth). This means that when it is exported to a file we can open in Civil 3D, there are multiple polyface meshes on top of each other representing the thickness (see image for example), we only need the top layer of polyface meshes to create a levels surface from.
How would I go about creating a surface from these polyface meshes that only makes use of the ones on the 'top layer'? Would I need to go through and manually delete all of the ones I don't need? Or is there a way it can be refined/converted in Revit before exporting to a DWG for us?
I can't share the CAD file unfortunately.
Any help would be great, thanks.
