Creating a Surface Based on Topographic Data
heather9UNHT
Observer Observer
Message 1 of 8
heather9UNHT
Observer
Observer
I am trying to create a surface based on topographic survey data. I created a polyline as a boundary for the area I want to focus on. When I try to create the surface I keep getting this error. I was trying to create it based on the boundary line I made. Any suggestions?
Replies (7)
Message 2 of 8
Pointdump
Hi Heather,
Welcome to the Autodesk Forums.
Hard to say without seeing your drawing and data. Can you post your drawing and the survey data?
Dave
Dave Stoll
Las Vegas, Nevada
NVIDIA Quadro P5000 16GB
Windows 10 Pro 64 / Civil 3D 2025
Message 3 of 8
heather9UNHT
Observer
Observer
Message 4 of 8
Wojty1
Hi Heather,
the screenshots you provided are not sufficient to tell what could cause the error(s).
Could you save and upload a Log File of the errors as shown below. This may help narrowing down the causes.
Then could you also post a screenshot of your Surface Definition (on the Surface Properties Dialog Box, see below).
Without further details it will be difficult to find the cause.
Windows 10 Pro 64-bit | Civil 3D 2024+2025 / Revit 2024 (64-bit EN)
Intel Core i7-7700K / 2x 27" / 64 GB RAM / GeForce RTX 3060 OC V2
Windows 11 Pro 64-bit | All Autodesk Products 2023 - 2025
Intel Core i7-13850HX / 3x 27" / 128 GB RAM / nVidia RTX Ada 3500
Message 5 of 8
heather9UNHT
Observer
Observer
When I try to develop a table from the arrow nothing show up!
Message 6 of 8
heather9UNHT
Observer
Observer
Message 7 of 8
Pointdump
Hi Heather,
Can you post your drawing(.dwg file) and the survey data(points? contours? dtm?)?
Dave
Dave Stoll
Las Vegas, Nevada
Message 8 of 8
ChicagoLooper
@heather9UNHT
Would it be possible to click on a contour line, then with the contour still selected, take a screenshot of the Properties Palette? This screenshot will be a good start because it'll reveal info about the selected objected, e.g. TINN, 3D polyline, block, etc., etc.
The screenshots you've uploaded so far don't provide enough information. You can also use the view cube to get a 'Front' view (not orthographic). Upload a screenshot of the straight on Front View.
Chicagolooper
