Solved by tcorey. Go to Solution.
Hi Dean,
If I am reading you correctly, you're saying you have a small surface, through which the alignment runs. That, to me, says that the alignment extends beyond the bounds of the surface. You should not expect your surface profile to do the same. It will only show the portion that is within the bounds of the surface.
As far as the surface being weird-shaped, are you only adding the points along the alignment and no others? One thing you can do is replicate the points to each side of the alignment and add the original polyline as a surface breakline.
Tim
