Create surface of many islands
m_kingdon
Advisor Advisor
m_kingdon
Hi all,
I need a create a surface for many FFL slabs which are defined using Feature Lines organised into sites.
I was hoping to create one surface and use breaklines and outer boundaries to define all FFL.  Is this possible?  Or do I need to create a surface for each individual FFL slab and Paste them together into a master FFL surface?
Mike Kingdon
Civil 3D Zealot
Jeew-m
I think grading would be a better option.
Jeewana Meegahage
Design Engineer
Autodesk Civil 3D Tutorials
Facebook | YouTube | LinkedIn
m_kingdon
Thanks for the suggestion.  Grading is not a better option for my current task.
Mike Kingdon
Civil 3D Zealot
keith_sowinski
Draw a closed poly line boundary that encompasses all of areas. It can be much bigger than your area of interest. Add this to the surface as a hide boundary. Then add each of the smaller area boundaries for each area as show boundaries.
m_kingdon
This method works great.  Thanks for your help.
You have saved me a lot of time creating and organising many surfaces.
Mike Kingdon
Civil 3D Zealot
