Create Section View Default Section Label Set Style does not work
swatfor_PDCOG
swatfor_PDCOG
Civil 3D 2019
When I set the label set style for Create Section View to No Labels, it still comes up with Major and Minor Offsets instead of No Labels.  (please see attachment)
This has been a problem with several past editions.
Tom Berning posted something similar in 2008
https://forums.autodesk.com/t5/civil-3d-forum/section-view-default-label-style/m-p/2236628
with no answers.
Label set settings for Create multiple section views works fine.
What am I missing?  It is very cumbersome to have to set each and every label set for individual sections.
Sandy W.
Neil.Aryan
@swatfor_PDCOG
can you send or attache the effected file ? i think this can be fix. i had something similar problem for section view labels.
will be great if check the dwg to fix the issue.
Did you found this post is unique ? Hit Like Button.
Did this post resolved your issue? Hit Accept as Solution & Like Button. This will be helps others to solve the issue.
Cheers,
Neil
Founder Director | Neil Engineering Consultancy
Certified Civil 3d Professional | (Old) YouTube | (New) YouTube
swatfor_PDCOG
The drawing is attached.  I checked it a few more times and the problem is now random.  When I first ran create section view, the "no labels" set came up.  If I backed up and picked another section, the Major and Minor label set reappeared.
Once you give it a try, if things appear to be going as expected, try a few different stations.  Even opening and closing the drawing (or some other drawings, for that matter) gives random results.
For this case, sometimes Civil 3D acts as expected and sometimes it does not.
Thanks for taking a look.
Sandy W.
Neil.Aryan
@swatfor_PDCOG,
I see in the drawing and found that source of label reflecting from. Its reflection through section label set << Major and Minor offset label style. once removed the label set (or make the style nil) easily individual sections can be generated without default labels.
find the attached drawing for your use.
Also you can find the video of same here.
Let me know if you were looking for something different.
Cheers,
Neil
swatfor_PDCOG
thanks Neil
Sandy W.
