Create Points on Grid Without Entering A Description
dbinkney
dbinkney
I have a large surface I want to convert to points on a 5x5 foot grid.
I am using the Create Ground Data > Points > On a Surface > On a Grid
No matter what options I select for:
Prompt for Elevations
Prompt for Point Names
Prompt for Description
(Automatic, Manual, or None)
I am asked to enter a point description.  I DO NOT WANT any point descriptions.  Why can't I have this automatically created?  What am I missing?
cwr-pae
Under the settings tab of prospector, open the heading 'Point'  and the subheading 'Commands'. Right click 'CreatePoints' and pick 'Edit Command Settings'.  Under 'Points Creation' you can set the default options used when creating points.
dbinkney
Thank you, changing the defaults made the operation work as expected. Much appreciated.
