Create paddy filed and the river on the given surface
hi everyone
i am trying to create the paddy filed and the river on the given surface
but i have no alignment data
all i have is contuor lines, paddy filed (2D polyline) and the river (2D polyline)
so i used the breakline command
but it came out with the very rough surface
what is the best way to create those?
thank you very much
Jeew-m
Nice to hear that people are creating paddy fields using Civil 3D. 😊
All depends on the accuracy and amount of data you have with you.
Additionally you can try for smooth surface.
Jeewana Meegahage
Design Engineer
Autodesk Civil 3D Tutorials
Facebook | YouTube | LinkedIn
lynn_zhang
Hello @Anonymous , thanks for posting!
I've edited the subject title of your thread so it better describes your problem.🙂
Did the response from @Jeew-m help solve your problem? If yes, please click on the "Accept as Solution" button in his reply so this helps other users in the community find the solution too. Thanks!
Lynn Zhang
thank you so much
already solved with the surface edit (delete points or move points)
thank you so much for editng my title
lynn_zhang
Awesome! Glad to hear you've solved the problem and thanks so much for sharing the solution! It will benefit other users with the same problem 🙂
Lynn Zhang
