Create Mass Haul Diagram
Can anyone please share the complete steps of creating a mass haul diagram with earhtwork table showing cumulative ctu/fill/net volumes? I have my alignment, EG, PG, Datum and Corridor. I use data shortcut to insert all of these.
As far as I know below are the steps but I'm not sure if they are correct or if I'm missing any step:
1. Using data shortcut, insert EG, PG, alignment, datum and corridors
2. Create sample lines (50' spacing)
3. Analyze >> Compute materials - compute material window opens up but I don't know what options to select
4. Analyze >> Mass Haul
Do I need to make cross sections after cutting sample lines?
wfberry
As far as I know you will need some kind of accumulating cuts and fills as you move down an alignment and X-Sections are the way to go.
I am posting a several years old AU class that is still viable today.
Bill
lynn_zhang
Hello @Anonymous ,
Just checking to see if your problem has been solved. Did the above response and the resource help answer your question?
Lynn Zhang
