- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Hi there
I have a special problem and found no way to solve it automatically. May someone out there has an idea....
I have a feature line with a grade of -5% (red line). Now i want to create another line (blue) which has a grade of -15%. The slope between the two lines should always be 1:1.5 (y:x) (66%).
I can split my red line in sections and calculate the offset manually to construct the blue line...but i want to have it exactly...and when possible FASTER than this method
Any ideas?
PS: For the context: The red line is the right side of a road and leads into the ground level of a building (garage). The building is on a hill and the blue line is the left side of a road and leads into the basement of the same building. The slope between cant be more than 66% (Earthwork) and the whole construction should as less area as possible.
