Create distance to point
Message 1 of 9
Dear sir /Madam
Ih problems when subassembly composer create distance to point .
Thanks you
Best regards
Accepted solutions (3)
Replies (8)
Message 2 of 9
tcorey
Can you give more details? Post your .pkt file?
Tim Corey
MicroCAD Training and Consulting, Inc.
Redding, CA
Autodesk Platinum Reseller
New knowledge is the most valuable commodity on earth. -- Kurt Vonnegut
Message 3 of 9
Dear sir.
this is file Pkt file  and dwg typicall CS
Message 4 of 9
Dear sir
why i can't attach PKT file
Message 5 of 9
M_Obradovic
You can't attach PKT file but you have to change extension of PKT to ZIP. Or just to zip file and than you will be able to attact to forum.
Message 6 of 9
thank you for your advice
this is my PKT file
Message 7 of 9
tcorey
I have your pkt file. Can you post a screenshot where in the flowchart you are having the problem?
Tim Corey
Redding, CA
Message 8 of 9
Dear sir
that is the  problem when i try to create line between P14 and P13 it not happen.
Message 9 of 9
tcorey
You have the Cut and Fill backwards in that first decision. You are using AP2.y>P11.y as your condition, but then saying False = Cut. AP2 is being placed on the surface, so that being higher than the test point, P11, would mean Cut should be assigned to True and Fill to False.
Tim Corey
Redding, CA
