CREATE DATA BAND FOR EVERY PROJECT GRADE VERTEX IN SECTION VIEW
MagnoVedovatto
MagnoVedovatto
Hello. I have a section view of an existing ground and the proposed ground (project). The section view of the project is pretty much only straight lines, and I need a data band that labels elevation of the vertex of the project. I'm gonna disply an image below for you guys to know what I'm talking about.
(The magenta lines represents what I mean)
By the way, the data band it already has it's slope breaks of project and existing ground grades, not the vertexes, although it may target a vertex occasionaly.
surafeltklt
you could do this by creating a band set now to do this go to setting which is below the prospector tab from the list find section view then band style and the go to section data and create new style then click edit the compose text tab on the right side  if you want to display like whish surface is being displayed on that band title box and then edit grade breaks so that it labels surface offset and elevation which is done by selecting grade breaks then clicking compose labels and edit the content from that go to display tab and make sure the grade break thick and label are set to be visible and set the others like major and minor tick and label are set not visible I do this to make sure there are no overlapping texts the use section data style to create a data band set while you do this edit the weeding to be small number like one or two meters so that grade break that are less than those numbers will not be labeled and  then you are good to go. I know this my not be clear considering my English is not that good so I attached u screen recording of how I did this thank you sir.
