create alignmnents from multiple corridors with code set
mohamedashraf2014m
mohamedashraf2014m
hi everyone, i need a dynamo script to select specific corridors then extract alignments from these corridors with code set for example all ETW alignments to be extracted from corridor if anyone can help?
rosie_lucas1
Hi @mohamedashraf2014m,
I wanted to check in and see if you still needed assistance, or if you found a solution to your question already? Let us know if you need further assistance by providing an update or if you have found a solution, please share it with the community so other members who may have the same question could learn from your experience.
All the best,
Rosie | Community Manager
ecfernandez
Is something like this what you are looking for?
I hope that helps. Best regards!
Camilo Fernández
P.Eng | Transportation
LinkedIn
rosie_lucas1
Hello @mohamedashraf2014m
Did the information provided by @ecfernandez help you and answer your question?
If yes, please click on the "Accept Solution" button on the post(s) that solved your problem. This will assist other community users in finding and benefiting from this information.
If not, please do not hesitate to give an update in this thread so all community members receive an update on the progression of your question, and can suggest next steps that may be helpful for you to achieve what you're looking for.
All the best,
