Recently installed 2018. Want to play with rehab corridors. Help documentation says:
Click Home tab > Create Design panel > Rehab Corridor
I have no "Rehab Corridor" in my create panel. Just regular corridor.
Am I missing something?
The corridor button on the ribbon should have a little down facing arrow that will open up a menu showing the selection for a Rehab Corridor.
Dear Friend,
Rehab corridor is in an update of Civil 3D. You need to install the update. Then it will appear below corridor as pointed out by MMcCall402.
Else you can install Civil 3D 2019. It has inbuilt Rehab corridor.
Dear Friend,
I have all the updates installed and still no rehab option.
Ok, it's something with my custom workspace.
The option is there when using the default Civil3D workspace. But if I just duplicate that workspace, no other changes, and set it active, I get no rehab corridor option.
And I don't see any sub-options (like with the parcels button) under corridor in the CUI.
