- Mute
- Permalink
- Report
I think it would be easier to explain my final goal before going into my question so no on is confused by my post, I'm very new to C3D:
I have a river that I've created 50 or so cross sections for. I'm attempting to create a proposed surface that will be used against the EG to calculate cut and fill volume and make printable layouts for each cross section. The proposed surface will follow a mutual grade and will need to be aligned to the thalweg on each cross section.
With that being said, I'm going to need to be able to replicate this process easily across over 100+ cross sections, and the thalweg obviously lands on a different point on each cross section.
What is the easiest way to create the proposed surface for these cross sections? Will I be able to depict the final result uniformly on a layout?
Best,
A
