Create a polyline using an alignment
Message 1 of 9
Hi all,
I have created an alignment using "Alignment Creation Tool" in civil 3D. How can I create a polyline using this alignment ?
Thank you.
Replies (8)
Message 2 of 9
Jay_B
One way is to offset the alignment (using autocad offset command), offset the resulting polyline the same distance back to alignment location.
Erase original offset polyline.
C3D 2018.1
C3D 2016 SP4
Win 7 Professional 64 Bit
Message 3 of 9
wmejiagomez
Hello. you can xplote the alignment.
Message 4 of 9
wmejiagomez
You can xplote the alignment two times and it will transform into lines and you can join those lines with the JOIN command.
Message 5 of 9
Joe-Bouza
What is the need?
Joe Bouza
Message 6 of 9
neilyj666
Why would you do this - the OFFSET method suggested by @Anonymous is far simpler
neilyj (No connection with Autodesk other than using the products in the real world)
AEC Collection 2026 UKIE (mainly Civil 3D UKIE and IW)
Win 11 Pro x64, 1Tb Primary SSD, 1Tb Secondary SSD
64Gb RAM Intel(R) Xeon(R) W-11855M CPU @ 3.2GHz
NVIDIA RTX A5000 16Gb, Dual 27" Monitor, Dell Inspiron 7760
Message 7 of 9
Joe-Bouza
I concur.
I'm still curious what the goal is
Joe Bouza
Message 8 of 9
Hi Joe,
May be not a good practice but when I do drafting, I prefer to off alignment layer and work with a polyline.
Thank you.
Message 9 of 9
Joe-Bouza
That's cool nimcha2001, is it an offset or are you wanting to manipulate the align itself?
The edit alignment tool bar has tools similar to edit poly lines.
Offset alignment are very useful drafting tool if you want your line work tied to the alignment
Joe Bouza
